LabVIEW Communications System Design Suite
Reading GPS data from Arduino
I am currently trying to read GPS data from an Arduino UNO through LabVIEW Communications. Is there anything similar to an NI-VISA driver for LabVIEW Communications vs. regular LabVIEW?
If not, any way to communicate between the USB ports and LabView Communications would be swell.
Thanks.
(4,521 Views)
Is there any reason you want to use LabVIEW Comms instead of just LabVIEW?
With LabVIEW there is a 3rd party tool that helps allow for communication between LabVIEW and Arduino:
Can I Control an Arduino from LabVIEW?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019SSZSA2&l=en-US
Hope this is helps!
(4,486 Views)
If you want to us Comms/LabVIEW NXG/have code in there already you don't want to re-write, you could try the LabVIEW NXG "VI Interop" node which allows you to call LabVIEW code in LabVIEW NXG: https://www.ni.com/docs/en-US/bundle/labview-nxg-nodes-api-ref/page/interoperability-nodes.html
It might allow you to add a node that just talks to the Arduino using the LabVIEW library but I am not sure.
LabVIEW NXG does allow you to send and receive VISA commands, but probably does not have a whole driver for the Arduino.
Rahul B.
(4,481 Views)
