LabVIEW Communications System Design Suite
Sampling Rate modifying in Deploying an Application to an FPGA
I am studying the performance of the OFDM(100MHz BW needed) using NI USRP 2954R. For this, I need the 100 MHz bandwidth.
OFDM Parameter values that I calculated are belows
 FFT_Size =  2048 x 5 = 10240
CP Length = 128 x 5 = 640
Sampling rate = 30.72MHz x 5 = 153.6 MHz
Used Sub carrier = 6000
Occupied_BW = 15000 x 1200 x 5 = 90MHz
Is it Possible with USRP 2954R(160MHz BW) ?
 I can't modify even sampling rate in EXERCISE 5 - Deploying an Application to an FPGA Example......  I have been doing for 4 days.....
Any help is greatly appreciated.
Thanks!
(3,422 Views)
Sorry , FFT_Size is 8192
(3,404 Views)
Hello!
Are you trying to just implement OFDM, or are you trying to implement other functionality in the PHY? Also, were you working with the Multirate Diagram?
This should be possible with the 2954 since each daughter board is capable of 160 MHz BW, and the FPGA should be clockable at that speed.
What issues have you been running into so far?
Cheers,
Rahul
Rahul B.
(3,375 Views)
