LabVIEW Communications System Design Suite
Transmitting udp data in excel file through LTE application framework
I am using LTE application framework module of LabVIEW communication system design suite.I want to transfer a known data between two USRPs. Taking reference from Video streaming example I am trying the same with MS-excel.After starting cmd.exe and changing the directory to the excel installation directory,I am using following commands :-
At transmitter :-C:\Program Files (x86)\Microsoft Office\Office12\EXCEL.EXE " C:\Program Files (x86)\Microsoft Office\Office12\tx.xlsx” :sout=#std{access=udp{ttl=1},mux=ts,dst=127.0.0.1:50000}
At receiver:-EXCEL.EXE udp://@:60000 .
But no results are visible.
(3,958 Views)
@kj@iiitd can you please tell where can i find the video streaming example for lte application framework.
(3,443 Views)
Page no.10 of the attached pdf
(3,439 Views)
