LabVIEW Communications System Design Suite
[USRP-RIO] IQ imbalance in stock streaming example
we are using the following setup:
  • A USRP-RIO is connected via PCI card to a desktop PC
  • An external signal generator is used to produce a test signal
  • The test signal is split 3-way and distributed to USRP Ch0, USRP Ch1 as well as a spectrum analyzer
The USRP receiver clearly shows some severe IQ imbalance, while the spectrum analyzer produces the expected result.
Is this the expected receiver characteristics of the USRP-RIO?
Is there a way to calibrate the device or do we need to estimate and compensate the imbalance manually?
Nicola
Message 1 of 1
(5,391 Views)
