LabVIEW Communications System Design Suite
Welcome to the LabVIEW Communications Discussion Forum!
Thank you so much for your explanation.Actually, I have another problem concerning the results of my PSK modulation.
when I run my transmitter on QPSK modulation I got this image :
Capture2.PNG  and I don t know exactly where my fault is.Can you please help me
Message 11 of 18
(7,902 Views)
Sorry I was missing the filter parameters.the samples per symbol were not matched.
Message 12 of 18
(7,899 Views)
Hi emnajaoua,
This thread is more of just introductions. You may want to start a new thread for your specific issues or post in a similar topic. You will get better visibility there.
David C
Message 13 of 18
(7,884 Views)
@Nick-C wrote:
All,
Welcome to the discussion forum for LabVIEW Communications System Design Suite! This is an open forum for users of LabVIEW Communications to share their product related questions and knowledge with each other. Like our other NI discussion forums, NI engineers will be active in helping to resolve questions and provide feedback.
For getting started materials, tutorials and example code, try visiting the SDR Community
Sir,
I am running example OFDM tx & rxCode on USRP 2943 . In receiver VI , in CFO Correction dependencies one block "Ramp pattern by samples" is showing error
"This method call node couldnot find its target. The target may have been moved renamed or deleted".
Please specify and locate how to get the asked target?
Thanks & Regards
Lucky
Message 14 of 18
(6,093 Views)
Please suggest how to get the target block in attached picture.
Code: OFDM TX & RX
Hardware: USRP 2943
Error in: CFO Correction Dependency "Ramp Pattern by Samples".
Message 15 of 18
(6,092 Views)
Hi Lucky,
Please create a new post with your questions so that other community members and AE support will see it.
Thanks!
Message 16 of 18
(6,091 Views)
Hello Everyone, I'd like to measure my experiment data by using two Keithley 2000 which are controlled by Labview software. But I have some problem this labview block diagram, that I wrote, it can run but the sequence of channel changes every time, and both keithley 2000 aren't simultaneous. If who do have any idea to write Labview block diagram better than me, please introduce me. Thank you.
Message 17 of 18
(5,198 Views)
Message 18 of 18
(5,197 Views)
