07-07-2016 01:53 PM
Hello all,
Does anyone know where I can find an example project or VI that uses the FFT IP from Xilinx in a CDL?
A simple example which configures the FFT in run time via 's_axis_config' bus and then computes one transform is OK.
Thanks!
08-30-2016 10:57 AM
You can check the subVI Xilinx FFT.gcdl in 802.11 Application framework. It is a good example to use as reference to implement a Xilinx FFT.
You can also use Xilinx FFT datasheet available in below link to understand all inputs and outputs.
http://www.xilinx.com/support/documentation/ip_documentation/xfft/v9_0/pg109-xfft.pdf
