LabVIEW Communications System Design Suite
deploying a labVIEW 2012 vi to USRP NI 2920
I have a LabVIEW VI to transmit and receive using modulation techniques using the USRP 2920. Basically, I would like to deploy the VI into the USRP NI 2920 and not depend on a desktop computer. Any advice on how to proceed with this would be appreciated.
Message 1 of 10
(6,114 Views)
You will not be able to do this with LabVIEW and the 2920. However, a simple solution is to have a small device like a Raspberry PI or a Beaglebone Black run the host code and control the USRP. You may also want to investigate gnuradio for controlling your 2920.
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
Message 2 of 10
(6,112 Views)
Cheers,
Michael
Can you cite where stated that is not supported or anywhere that this can't be done? If possible
Message 3 of 10
(6,104 Views)
Accepted by topic author cdiaz093
Its probably documented, but the 2920 does not have a processor, so it can't run stand-alone. You can build an executable in LV to control the USRP without LabVIEW, but it doesn't have the capability to run headlessly.
You could possibly try a small stand-alone computer, though you would have to figure out streaming bandwidth (not sure what Raspberry Pi, etc. can handle) etc. on your own, so you could run into performance issues.
Rahul B.
Message 4 of 10
(6,097 Views)
The NI 2920 does not have an on board OS. NI-USRP, the driver required to run the 2920 requires an OS to run. Alternatively, you could use the FPGA to implement this functionality, but LabVIEW does not allow for user access to the NI 2920 in this way. Therefore the 2920 will not work as a disconnected device using LabVIEW. You could investigate how to do this is GNUradio, but I'm not certain about whether that will work.
What is the overall application? Maybe there is another solution.
Michael Bilyk
Message 5 of 10
(6,095 Views)
Using TX and RX to transmit between usrp 2920s, but for our application we can't use the desktop computer,  we tried LINX add-on with beaglebone but keeps getting errors when deploying the USRP AND IMAQ toolkits.
Message 6 of 10
(6,085 Views)
I forgot to mention we are also using the b200, would this be possible?
Message 7 of 10
(6,044 Views)
It has the same problems as the 2920 listed above.
Michael Bilyk
Message 8 of 10
(6,040 Views)
So instead of having the beaglebone handle the usrp, can we have the NI myRIO do that? This embedded device is supported more by labview and NI and does not require the LINX add-on to deploy to it.
Later, we can link the beaglebone and myRIO to get all the data from sensors in the beaglebone passed over to myRIO.
Message 9 of 10
(6,031 Views)
Decided to go with a single board computer running windows 10.
Message 10 of 10
(5,974 Views)
