LabVIEW Communications System Design Suite
interfacing opc server with delphi ide (pascal)
Dear all,
can u please tell me how to interface the opc server with delphi ide (pascal)?
Actually i have connected my s7-400 plc with ni opc servar and i want to interface all tags to delphi ide (pascal). but i dont know how to do it, there  must be a process or tools or anything,.
(4,153 Views)
Hi Mahmilton,
Are you using LabVIEW Communications for this and is there a particular reason for using LabVIEW Communications? You will probably have more luck using regular LabVIEW instead and posting on a different board. This forum is specifically for users using LabVIEW Communications.
If you are not using LabVIEW Communications for this than I would post in the Industrial Communications Forum instead.
Cheers
Michael Bilyk
Former NI Software Engineer (IT)
(4,140 Views)
hi AgentAstronaut,
Thanks for your reply. i couldnot understand where to post my tread. can u help me to find out the suitable place.
(4,135 Views)
Hi Mahmilton,
AgentAstronaut gave you the link: INDUSTRIAL COMMUNICATIONS
George B.
(4,120 Views)
