LabVIEW Communications System Design Suite
samples lost
 I am transmitting one fixed pattern of samples in between random data .  The  total complex valued data which is transmitting is 6400000 and in between these  data i put five known complex data sequence of length 2560 in fixed interval,  so that in receiver side, i can correlate the known sequence with received  sequence and find the starting point of transmitted data. ( During correlation,  the output gives high peak whenever the two known sequence correlate, so as  there is total five known sequence in received data, the output shows five peak  in regular interval).  However, in receiver side, i never got five peaks, sometimes i got two or  maximum 4, but not in regular interval.  Tx. IQ rate = Rx. IQ rate = 5MHz and it is fixed. So please tell me what the number of samples for transmitting or receiving in  each cycle i choose so that the above problem can be fixed.  Thanks
(6,320 Views)
Hi A87,
What code are you using to transmit and recieve this signal? Could you post that here? Additionally, what device are you using? You may find posting this same question and additional information to our USRP Forum, and they may also be able to assist you.
Thanks!
BeenCoughin
(6,310 Views)
I am using ni USRP 2952 Rio.  First i save the transmitted data in .csv file and later transmitted using USRP.
(6,302 Views)
Hi A87,
Is it possible for you to post the code you are using here? Without getting a look at your code, we're going to run into some difficulty troubleshooting your issue.
Additionally, could you open up an example under "Examples" » "Hardware Input and Output" » "NI USRP Host" » "Single Device" » "Single Channel" » "Finite" and try one of the Tx examples and see if you can transmit properly?
BeenCoughin
(6,242 Views)
can you please post your code i need a help i want to get the channel response for this i have to transmit a known sequence via usrp
(4,765 Views)
