LabVIEW Communications System Design Suite
show me how can i make subVI 1 , subVI 2 and addressing pattern in this ping pong diagram
Untitled.png i need to use the ping pong diagram but i still not know how can i make this sub VI 1 , sub VI 2 and addressing pattern ,,,,,,,,, what eash of these consists of
Message 1 of 12
(4,892 Views)
You probably need to give significantly more information before we can help.
(EDIT: Ah now you at least added a picture. Still not clear what you want.)
What LabVIEW versions is this?
Message 2 of 12
(4,887 Views)
this version is  a labview communication
i need to use this ping pong to which doubles the size of the array and allows the loops to process separate halves of the array simultaneously.
Message 3 of 12
(4,865 Views)
Looks like Vee, not G.
Message 4 of 12
(4,849 Views)
Which version of LV Comms?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 5 of 12
(4,810 Views)
What are subVI 1 and subVI 2 supposed to?
Do you want to know how to make any subVI?
http://www.ni.com/documentation/en/labview-comms/2.0/g-prog/creating-a-subvi/
ALE Consultants
Message 6 of 12
(4,794 Views)
Ping pong, or double buffer, memory implementations tend to increase the throughput of an Optimized FPGA VI as compared to single buffer memory implementations, especially for VIs that include cascading loops.
Version:
Message 7 of 12
(4,774 Views)
This is an FPGA VI?  I did not know that.
Are your arrays fixed size?
ALE Consultants
Message 8 of 12
(4,769 Views)
not fixed size
Message 9 of 12
(4,758 Views)
FPGAs do not support dynamically sized arrays.
ALE Consultants
Message 10 of 12
(4,752 Views)
