LabVIEW Development Best Practices Discussions
Folder delete protection
hi friends,
Is it possible to make protection to folder from Delete operation by using Labview?
i need urs help?
(6,112 Views)
I am not well sure that you can get the 'Folder Reference' for modifying the permission.
The simple workaround is
1. Write some dummy file into the Folder,
2. Get the access of the file (dummy file) / Deny Access of the file,
3. When you finishing the operation,
3a. Close the dummy file,
3b. Delete the dummy file.
Note:-
Here you have to run your code prallel to the delete operation.
Hope this can help you.
Yogesh Redemptor
Yogesh Redemptor
(4,171 Views)
Thanks for replay me...your idea is good..but i am thinking ..it is only protect to delete the folder...suppose if user delete  each file in these  folder individulay ,this idea is not worked....
(4,171 Views)
Yogesh Redemptor
(4,171 Views)
