LabVIEW Development Best Practices Discussions
How to implement OOP Plugin Framework Solution
i want use OOP Plugin Framework as main architecture for my application, but i cann't understand, how to activate plugins in a sequence and transmit data beetween plugins.
In sample solution for this Framework is given only a description how to run a non-interacting with each other plugins individually.
For example:
1. In first step i want to scan (using scanner) some barcode (i have scanner class and method "scan" - first plugin in sequnce). Result of scanning is a string with barcode information. This result i want to transmit to second plugin.
2. In second step i want connect to database and find information about test sample, using result from first step. (second plugin in sequence).
3. In thrid step i want to run some test, using information from second step and show to user testing results.
Thank you in advance,
Alex
Message 1 of 1
(5,127 Views)
