LabVIEW Development Best Practices Discussions
Is there a limit to how large a VI can be?
I am approaching 7MEG file size and will probably end up needing 10 Meg.
Message 1 of 19
(14,021 Views)
hummm well.. the question is how comes your VI is so large??
For instance if you put a large image (jpg for instance) on the front panel, that will affect the size of your VI.
But if there is no such thing and you hace 7MB of pure code then I'd love to see you diagram 😮
If you hit ctrl + i and select the "memory usage" tab, what does it say?
FP objects
BD objects
Code
Data
Total
Size on disk
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 2 of 19
(4,941 Views)
FP objects:  1870.3K
BD objects:  27249.2K
Code:  15218.0K
Data:   4032.9K
Total:  ~48370.5K
Size on disk:  ~7168.6K
Message 3 of 19
(4,941 Views)
In LV 6.0 or there-abouts the VI would break if the type descriptor for the FP
grew over 64K (?) but the limit on VI s since then
BD with a size larger that 32K pixels (?) crashes LV.
if you plan a keeping that VI, then I suggest you find out yourself and after BACKING IT UP (a zillion times to a server and your home PC) just astrt doing a "ctrl-a" ctrl-v on the diagram until it crashes. Please share the size that resulted in the crash, so the rest of us never go there.
Just trying to help,
Ben
Message 4 of 19
(4,941 Views)
15Mb of code... wow...
What is your application doing?
Do you not have any subVIs?
How big is the block diagram in terms of screen-scrolling?
What's the size of you screen?
Epictetus
Antoine Chalons
Message 5 of 19
(4,941 Views)
Wow, this gives new meaning to "large application development". I checked one of my more complicated VIs and it's memory usage is:
     FP: 91.2K
     BD: 1MB
     Code: 293K
     Data 271K
     Total: 1.7MB
     Size on Disk: 422KB
Use SubVIs and empty your Graphs, Charts, and Arrays before saving to disk.
Message 6 of 19
(4,941 Views)
Ok this is my dilemma:
For the people who have asked, I do have some SubVI's in my program.  Most of the program is written using property nodes over and over.  Shifting controls from one place to another making controls blink and hiding other controls.  I am using property nodes like blinking, visible and value.  Is it possible to make SubVI's that have property nodes in them?
Message 7 of 19
(4,941 Views)
Yes you can have property nodes in sub-VI provided you are coding
in a version more recent than LV 6.0.
I wrote a mini-Nugget on accessing control refs from sub-VIs this morning and you can find it here.
At the time I wasn't quite sure why i took the time but it must have been to handle this Q here today.
Ben
Message 8 of 19
(4,941 Views)
Absolutely. Pass a reference to the control to the subVI. In the subVI, you can use a "generic" property node to get and set properties of the control connected to the reference.
Message 9 of 19
(4,941 Views)
Instead of manually creating references and adding them to the connector pane, keep in mind that LabVIEW can create subVIs for you.  Simply select the portion of code you want to put into a subVI and select 'Edit > Create SubVI.'  I recommend modifying the connector pane it'll create to conform with your style guidelines, but it does most of the work for you.  LabVIEW will also warn you if creating a subVI risks changing the functionality of your code.
Also, Ben is right about backing up your code religiously, but I would highly encourage everyone to use source code control for this purpose!  TortoiseSVN is a great (and free) solution for this.
Elijah Kerry
NI Director, Software Community
Message 10 of 19
(4,941 Views)
