LabVIEW Development Best Practices Discussions
Specification Pattern caveat/alternative
User komorbela posted some useful alternative information about the Specification Pattern.  To avoid confusion in the main post, since the attachments are not examples for implementing the specification pattern but are instead a benchmark for comparing that pattern with alternative implementations, the attachments have been moved to this thread.
Komorbela said:
"A note for the ones who have a very fast system that is at the limit of the hardware it runs on:
When considering replacing cases in case structures with dynamic dispatch VIs the small overhead of dynamic dispatch can be an issue.
Here is the fact: calling the dynamic dispatch VI that belongs to the actual class is done in dynamically as the code runs. It necessary means there is some overhead (time punishment) while deciding which VI to call. At least this is the case in LabVIEW.
So before jumping into a refactoring of old running code make a small test to compare case selection vs. dynamic dispatch."
(10,073 Views)
It's strange that the 2012 version is faster then the 2013 version over all.
For dynamic dipsaptch about 5% faster, or is it just my computer?
(6,794 Views)
LabVIEW 2012 / LabVIEW 2013
time duration ratios:
0.91 - Dynamic dispatch
0.95 - Cast and Dynamic dispatch
0.99 - Cast and Static dispatch
1.04 - Cast and Static dispatch Inlined
So yes, dynamic dispatch is slower in Lv2013 at me also. Only the inlined static dispatch is faster in Lv2013
(6,794 Views)
Forum post by NI R&D confirming that dynamic dispatch is slightly slower in 2013 than 2012:
https://forums.ni.com/t5/LabVIEW/Big-Performance-Degradation-in-LabVIEW-2012/m-p/2699881#M801792
Message 50 in that thread.
(6,794 Views)
I am pleased to hear that! Good to know this problem is on the radar at NI
(6,794 Views)
