LabVIEW Development Best Practices Discussions
Unit Test Framework Toolkit Users: We want your feedback!
Daklu wrote:
I thought VIT was more suitable for OOP developers while UTF seems more aligned with LV procedural programming.
I'm not sure I agree with that - we've been able to acheive both with NI's UTF pretty easily.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 11 of 57
(3,535 Views)
Example code and or white paper?    It's been a couple years sinice I've played around with UTF and my skills have improved, so perhaps I wouldn't find it so cumbersome this time around.  Still, It'd be nice to avoid having to reinvent the wheel if possible.
Message 12 of 57
(3,535 Views)
Sorry Daklu, no can do
Message 13 of 57
(3,535 Views)
What about one of your lackys minions cabin boys coworkers like asbo or hoover?  Or maybe just a couple paragraphs describing what you do?
No?  Booooo!
Message 14 of 57
(3,535 Views)
It's not that I don't have time, it's that it's something I'd consider company IP, and I'm not comfortable sharing such.
PS: Cabin boys?! ;D
Message 15 of 57
(3,535 Views)
We're starting a new development effort, and it seemed like a good opportunity to try out the UTF and see what it could do, how it might integrate into our workflow, and what kind of cool stuff was possible with it.
It seems pretty solid for basic input/prcoessing/output testing. It'd be neat if there was a 'results vector' to go along with the input vector - that is, a table of expected results that would map one to one to the provided table of inputs.
Is there any way to customize/clean up the reports it generates? There seem to be some typos in the header information - like it reports an 'Operation System,' and there's one place that has a 'Targert IP'.
Message 16 of 57
(3,535 Views)
Daklu, UTF also allows you to create a "user-defined test" that gives you a blank slate VI to completely define how your test is run and validated.  This, to me, is similar to what JKI's tool gives you.
Message 17 of 57
(3,535 Views)
mc_vibraphone,
For customizing the report, to write a program to parse  "ATML" report which is in XML format, by using a XML parser, then combine the data in the way that you want.
If you have specific requirement in "customizing", could you let us know more detail such as how you want to combine the data (or what kind of flexibility you need)so we can analyze further to see if we can have the feature in the future release.
HaiJun
Message 18 of 57
(3,535 Views)
Yes, but wrapping a unit test for OOP code in a vi for UTF seemed like an extra step.  Granted, I have spent far more time with VIT than I have with UTF, and perhaps I just didn't discover good workflows with UTF.  In fact, Chris Relf's comment indicates that is likely the case.
I'd be willing to give the UTF another try if someone can confirm the bug in 2009 causing LV to crash when trying to remove a unit test from the project has been fixed.
Message 19 of 57
(3,535 Views)
Daklu,
> I completely agree with you that learning how to develop good unit tests is difficult and time consuming.
OK, agree.
> I don't think it's realistic to expect NI to have all the answers on how to go about developing unit tests for the UTF.
Agree as well.
BUT: One or the other example for non-trivial usage of any given tool would be considered VERY helpfull, especially when those examples are well documented. I'm not expecting explanation on WHY some test vectors where choosen, but why a special sequence of tests was chosen and what - if any - special comparisions or test criteria have been chosen.
This would help to understand what the devellopers had in mind how to use the tool. So one would work _with_ the tool and not _against_ it.
Message 20 of 57
(3,535 Views)
