LabVIEW Development Best Practices Discussions
iwebbrowser
Is there anyone out there familiar with the activeX controler called "Iwebbrowser"?
I was thinking on using this Windows activeX classes to make an application that would open a hotmail account and send an email (alert email, emergency email, you name it!).
(6,667 Views)
You can find the documentation of the IWebBrowser (Internet Explorer ActiveX objects) on the Microsoft site (MSDN Library). But why not use the SMTP E-mail VI's in LabVIEW? I'm not sure but doesn't hotmail (and Gmail) also support SMTP?
(4,468 Views)
They do, but require nowadays all authentification, which the SMTP Email VI's don't support out of the box.
That said, I don't think the IWebBrowser interface would be the ideal interface to do email conversation. I would rather go with a different interface such as Outlook or if it should be independant lower level interface such as IMapiSession.
Rolf Kalbermatter  My Blog
(4,468 Views)
Have you seen this example? (GMAIL.vi) I just tried it and it authenticated with gmail fine for me. I presume that with the correct server name, port and account info that it should work equally well for hotmail.
Note: I did have to complete all fields. The VI is a bit messy, but is a good starting point. No Internet toolkit required!
(4,468 Views)
