LabVIEW Electrical Power Toolkit
Comtrade logging and reading
I am trying to implement example project  "COMTRADE Waveform Logging VI: labview\examples\Electrical Power\COMTRADE Logging". I have cRIO 9076 with 9225  and 9227 modules. Example VI only writes voltage waveform to .dat file but I wanted to include current waveform as well. I am new to labview and not sure where to go about this. COMTRADE logging (FPGA).vi is sending data (FIFO) from 9225  and 9227 modules and I think only (COMTRADE waveform logging.vi needs to be modified to include writing current waveform in .dat and .cfg files.
Entire example project can be found:
Find Examples>Toolkit and Modules>Electric Power Suite> File Input and Output> COMTRADE logging and reading.lvproj
Any help will be greately appreciated.
(7,687 Views)
If you want to log current waveforms into .cfg and .dat files, you need to modifiy the COMTRADE Waveform Logging.vi:
1. Configure 4 more current channels' information in the control analog channel info:
2. Build the voltage and current waveforms into 1-D waveform array, and then bundle it with the digital data as the element for the queue:
(7,665 Views)
