LabVIEW Electrical Power Toolkit
Electrical power toolkit 2021
Hello
I would like to move to labview 2021 but the electrical power toolkit has not been released yet. Is there a workarround to use the 2020 version with labview 2021? Will it be released soon?
(8,334 Views)
Same issue. I wrote to a couple of NI guys, but no answer.
NI's support on this forum looks quite underwhelming.
(8,291 Views)
I've had to tinker with this in the past and it is only a set of VIs in vi.lib (and docs, examples etc) so if you really wanted this you can probably copy them from a 2020 installation to 2021 and then mass compile the folders.
I'm not saying I would necessarily recommend it! But if you needed 2021 now then it should work.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(8,286 Views)
Thanks, in the end I did what you suggest James, it was only for evaluating LV2021 for the moment. But on long term I hope to have EPT available officially (or at least a communication of if it will happen)
(8,282 Views)
