LabVIEW Electrical Power Toolkit
Ni usb 6211
Hi there. I'm trying to get frequency and rms voltage using my 6211 and electrical power suite, but the measurements that I've got is wrong or inf. Maybe is incompatible using 6211 with electrical power suite but I'm not sure.
Thanks!!!
(5,645 Views)
USB 6211 can be used with EPS toolkit. I suggest you using the example VI "Basic Power Measurement.vi" if you need to get frequency and RMS value.
This example measures 3Ux3I values. So please select 3 channels in "voltage channels" and another 3 channels in "current channels". Then adjust the maximum and minimum values for each other. For voltage, the span is +10 to -10. For current, the span is +0.04 to -0.04. Run the example and I believe you can get the appropriate values.
Thanks!
(5,596 Views)
Thanks!
(5,595 Views)
