LabVIEW Electrical Power Toolkit
Re: How to measure rms value of current and voltage by using LabVIEW?
I am working in a project where I have to display  the voltage(upto 220V), current and power of  three phase Generator on Labview  via Arduino Uno. How I will do it and which sensors I should used ? please help me
(6,528 Views)
Hi Shehzad05,
NI has several hardware instruments supporting power measurement, like DAQ, cRIO. Software wise, have you checked out the folder <National Instruments>\LabVIEW 201X\examples\Electrical Power  ?
If not, please first take a look. Hardware info, including sensor info (like NI 9244, 9227, etc.), is included in the project file.
(6,504 Views)
Wow via an uno?! You're going need something in the middle of that.
You may be best searching for people who have made home energy monitors with arduinos. I've seen them before so they must have a good solution
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(6,372 Views)
