LabVIEW Electrical Power Toolkit
Where can I find a white paper describing the resampling algorithm?
Where can I find a white paper on the resampling algorithm?
(7,978 Views)
There are some basic concept introductions about resampling in a shipped document, which is located at National Instruments\LabVIEW 2012\help\lveptconcepts.chm
The resampling algorithm is widely used in many other areas, whose signal processing principles are similar, such as the below reference,
https://ccrma.stanford.edu/~jos/resample/
(7,974 Views)
