LabVIEW Embedded
About lm3s8962
I use labview2009, on the arm module. I do not want to use the rtx-nuclear, may It? Is that a OS?But each time the compiler is called rxt nuclear. And my ARM in the simulation, when, and why not generate hex, or the bin file. Thank you ! loyal customers
(6,046 Views)
The arm module is based on keil, and keil need the RTX kernel installed on the arm, so it is necessary for you arm developpment.
District Sales Manager | Shanghai Pudong, China
(6,029 Views)
