LabVIEW Embedded
Accessing Onboard ADC with LabVIEW for ARM
I am working with the LM3S9062 Evaluation board and LabView for ARM system, and want to measure an analog voltage using the ADC, however I cannot determine which of the Digital Inputs is linked to the ADC. I need to know how the gpio mapping corresponds to the pinout of the Device.  Any thoughts?
(6,639 Views)
Do you mean the LM3s8962 evaluation board?  If so, the pins should be labeled accordingly on the board - ADC0, ADC1, ADC2, etc.
Drop an EIO node with the same name as the pin and it should work fine from there.
Here are the schamtics :  http://www.realview.com.cn/UploadFile/2008111510295067433.pdf
(6,638 Views)
Yes I did mean the 8962.  Thanks for the correction. As far as the pin labels, the problem is that on the project explorer nearly everything is labeled as a GPIO when I add a new Elemental I/O, which must be assigned to the EIO block, or so I understand. I am not sure which corresponds to the ADC.
(6,635 Views)
You should be able to right click on the target and select "New >> Elemental I/O" and see the following:
Once you add new EIO with this dialog you should be able to add them to your VIs.
(6,631 Views)
