LabVIEW Embedded
Adopt emb.LV to emb.Linux Target ARM9 Prozessor
hello,Mr Michael
   The error aboved is solved,but the new linking error appeared as follows:
Linking error:
lvEmbeddedMain.o:lvEmbeddedMain.c:(.text+0x49): undefined reference to `_LV_unix_init'
lvEmbeddedMain.o:lvEmbeddedMain.c:(.text+0x4e): undefined reference to `_LVCGenRTInit'
lvEmbeddedMain.o:lvEmbeddedMain.c:(.text+0x83): undefined reference to `_LVCGenRTRunTopLevelVI'
lvEmbeddedMain.o:lvEmbeddedMain.c:(.text+0xa1): undefined reference to `_LVCGenRTEnd'
lvEmbeddedMain.o:lvEmbeddedMain.c:(.text+0xa6): undefined reference to `_LV_unix_fini'
test.o:test.c:(.text+0xc4): undefined reference to `_RunVI'
collect2: ld returned 1 exit status
I don't know how to define the function in the target.
thank you!
lianzi
i like thinking ,i enjoy doing the work.baxia
Message 31 of 56
(7,001 Views)
These functions are defined in C files in the runtime libraries, here <CCodeGen\libsrc\os\unix\LVUnixInit.c> and here <CCodeGen\libsrc\os\unix\ lvcgenrtinit.c>. These files need to be included when you build the runtime libraries and must be linked in.
Michael P
Message 32 of 56
(6,997 Views)
Hello,Michael
      I found these functions in the CCodeGen,but I don't know  how to build the runtime libraries ?
IN the chapter 7-Porting the LabVIEW Embedded Run-Time and Analysis Libraries Source Code,I don't find the methods to build the library.Can you give an example ?
Thank you!
lianzi
Message 33 of 56
(6,988 Views)
How you build the run-time libraries depends on your tool chain. In most cases, a makefile is the method of choice. An example of this is located in labview\Targets\NI\Embedded\unix\build\.
Michael P
Message 34 of 56
(6,971 Views)
hello.Michael
 The errors above  are sloved,but there is still a new question as follows:
/usr/local/lib/gcc/arm-elf/3.4.0-macraigor1/../../../../arm-elf/bin/ld: cannot find -lc
I installed  gnutools-arm-elf-2.05.exe ,and I change it for the gnutools-arm-elf-2.04.exe,but the error is the same.
Maybe it is the problem about third toolchain.
Can you give me some advice?
Thank you!
Lianzi
Message 35 of 56
(6,952 Views)
Can you give me the exact command string sent to the linker?
Michael P
Message 36 of 56
(6,946 Views)
Hello,Michael
The linker is "-g -m5307 -lc -lpthread -lgcc -lm -lstdc++"
Message 37 of 56
(6,944 Views)
It appears that there is something wrong with the installation of the gcc toolchain you are using. Are you able to compile and link a simple C program? What version of the toolchain are you using, and where did you get it?
Michael P
Message 38 of 56
(6,938 Views)
Hello,Michael
        The  gcc toolchain i used is gnutools-arm-elf-2.05.exe,where i down form  here:http://www.ocdemon.com/gnutools-arm-elf-2.05.exe.Is it right?
Message 39 of 56
(6,931 Views)
Hello,Michael
         Is the gcc toolchain  i chosed right?And there is another question occured to me,that is i can't build the makefile successfully,The makefile is in the attached files.
Thank you for giving me your advice.Thank you very much!
../CCodeGen/include/blockdiagram/MemCheck.h:27: warning: data definition has no type or storage class
../CCodeGen/include/blockdiagram/MemCheck.h:28: parse error before `critsect'
../CCodeGen/include/blockdiagram/MemCheck.h:28: warning: function declaration isn't a prototype
../CCodeGen/include/blockdiagram/MemCheck.h:191: warning: function declaration isn't a prototype
In file included from ../CCodeGen/libsrc/blockdiagram/CCGArrSupport2.c:18:
../CCodeGen/include/blockdiagram/LVCCG.h:682: parse error before `gVICriticalSections'
../CCodeGen/include/blockdiagram/LVCCG.h:682: warning: type defaults to `int' in declaration of `gVICriticalSections'
../CCodeGen/include/blockdiagram/LVCCG.h:682: warning: data definition has no type or storage class
../CCodeGen/include/blockdiagram/LVCCG.h:688: parse error before `gReentrantCritSect'
../CCodeGen/include/blockdiagram/LVCCG.h:688: warning: type defaults to `int' in declaration of `gReentrantCritSect'
../CCodeGen/include/blockdiagram/LVCCG.h:688: warning: data definition has no type or storage class
../CCodeGen/include/blockdiagram/LVCCG.h:689: parse error before `gStepCritSect'
../CCodeGen/include/blockdiagram/LVCCG.h:689: warning: type defaults to `int' in declaration of `gStepCritSect'../CCodeGen/include/blockdiagram/LVCCG.h:689: warning: data definition has no type or storage class
../CCodeGen/include/blockdiagram/LVCCG.h:706: stray '\' in program
../CCodeGen/include/blockdiagram/LVCCG.h:707: stray '\' in program
../CCodeGen/include/blockdiagram/LVCCG.h:708: warning: type defaults to `int' in declaration of `argName'
../CCodeGen/include/blockdiagram/LVCCG.h:708: `tlAL' undeclared here (not in a function)
../CCodeGen/include/blockdiagram/LVCCG.h:708: warning: data definition has no type or storage class
Message 40 of 56
(6,906 Views)
