LabVIEW Embedded
Are there any EZLite537 Embedded LV examples for using the serial, USB, and ethernet ports? Thanks, Dave, wilbonda@yahoo.com
There is a TCP/IP example in your "Getting Started with.. EZ-Kit BF537".  If you go to page 2-1, there is an example on writing a TCP application using Visual DSP.  Note that you can use TCP function calls and develop your own program in LabVIEW.
I believe the USB port for the BF 537 is used for debugging purposes.  It is a dedicated USB connection between your PC and the EZ-KIT.
As for serial, take a look at the Serial Compatibility VIs located on the  Instrument Control palette.  Note that when accessing the serial port programically, you must uncheck the "Redirect stdout to serial port" box in the advanced tab of the Build Options dialog.
I hope this helps,
Nadim
Applications Engineering
(6,327 Views)
