LabVIEW Embedded
BF Flag Suspend Callback vi & BF Flag Resume Callback Vi Error
Hi every one!
 I have a trouble in programming with BF Flag Suspend Callback & Flag resume Callback vis. My project should catch external interrupt( PF5 rising adge), while interrupt is calling back a subrountine interrupt service i want to Mark this interrupt to process something then resume interrupt at the end of Subrountine. But when i put these Vis in my project then compile, it alway has error as atched files
 Please refer atched files and tell me what was wrong? I am thinking about error which may be from macros in Inline C node is not defined correctly. am i right?
 Here is my project code and capture file.
(7,515 Views)
remain my code here
(7,514 Views)
error capture file
(7,513 Views)
error capture file
(7,512 Views)
Hey Seoul,
It seems like you have not specified your header files right for the Call Library Function Node.
I will see if I can pin point anything out.
Could copy and paste the whole error message in a notepad so that I'll have all information available?
Aashish M
CEO
TransferFi
www.transferfi.com
(7,484 Views)
hey Aashish!
here is my full error indicating. pls read then reply me how about this error. I have spent so much time to solve this problem biut still was not successful.
Thank so much for your reply
(7,467 Views)
Hey Seoul,
Your callback VIs call resume/suspend in the callback. You need to do that in the main VI, not the callback.
You need to be very careful about what you do in callback VIs -- only set globals and fire timed loops.
No subVIs, no memory allocation.
Aashish M
CEO
TransferFi
www.transferfi.com
(7,399 Views)
