LabVIEW Embedded
Blackfin ez-lite embedded ezToggleLED.dll works but ToggleLED.vi doesn't
I have run the RTC Periodic example that comes with the EZ-lite Blackfin board.  When the example is run unchanged it works.  The second interrupt handler uses the ezToggleLED.dll.  When the second interrupt is modified by taking the ezToggleLED.dll out and replacing it with the ToggleLED.vi from the blackfin/Ez-Lite/LED vis...it fails.  The ToggleLED.vi is made up of two error handling boxes and the same ezToggleLED.dll
Here are the two subroutines.
No other changes were made in the program or the build specs.
Help.
Hummer1
(6,414 Views)
Here is a shot of the processor status window when the program runs.
(6,411 Views)
Hi Hummer1,
I will be looking into this issue for you first thing tomorrow morning. More to come soon.
Joshua B.
(6,384 Views)
Hi Hummer1,
Sorry for taking so long to get back to you. Can you zip your project and send it my way. I am currently unable to reproduce the issue, I guess I might be missing something.
Joshua B.
(6,357 Views)
