LabVIEW Embedded
Can't Insert VI while Processor Status Window is Open
I've found that you can't drop a VI onto your Block Diagram by chosing "Select a VI..." from your Functions Pallet while the Processor Status window is open.  Simply close the Processor Status window, or drag the VI icon onto your block diagram works while the Processor Status window is open.  Just a small bug, no biggie.
(6,786 Views)
Eric,
Thanks for reporting this issue. I have reported the issue to R&D.
Michael P
(6,768 Views)
