LabVIEW Embedded
Carriage Return and Line Feed with UART ASCII
Working on UART comm with the LM3s8962 and I am wondering how LabView handles the <cr><lf> that is involved with the UART commands from the user manual I am trying to communicate with.
For Example
*Q<cr><lf> (how do I enter that as a string in LabView to have it be recognized correctly.)
The other commands are the same minus a change in the Letter proceeded by the Asterisk.
(7,168 Views)
Hi Tilgath,
Does the device have to use these specific codes? Can you post the manual that has this information?
You can enter codes into a string in LabVIEW, but only slash codes (for example a space is \s) and hex codes. Right-click a string control or indicator in LabVIEW and see that you can select '\' Codes Display or Hex Display.
Stephen S.
Message Edited by Stephen_S. on 03-04-2010 02:58 PM
Applications Engineering
(7,139 Views)
