LabVIEW Embedded
Closing and opening projects makes inputs void MCB2300
I was finally able to figure out custom inputs and outputs for my MCB2300 board. I have a new problem however. I can start a new project, load a new target, place Microcontroller I/O's on the VI and they work. Then, when I reopen the project, all of the inputs change from "Boolean true / false" to "Voids". It doesn't seem to recognize them.
Is there some systematic way I should reopen files?
Mark
(5,926 Views)
Hey,
I think I figured it out. It seems you need to open the project first, then double click the VI assigned to the target in the project list. This appears to keep the associated EIO files so the I/O's on the block diagram are not dummies.
M
(5,921 Views)
