08-11-2009 07:35 AM
08-12-2009
12:05 PM
- last edited on
05-19-2026
10:51 AM
by
Content Cleaner
Hi Michael,
This is a very strange problem. Can you see the device in MAX when you put the controller in safe mode? If so you can try reformatting the controller in safe mode. This might help to fix any problems that might have occurred in the controller. Also, can you ping the hardware from the command line? This can tell you if it is even communicating to the Ethernet port at all. Finally can you communicate to it via crossover cable?
If you still cannot connect to it, it is possible the hardware has gone bad. You might be able to call support and get the device repaired or replaced.
08-12-2009 08:45 PM
Hi David,
Thanks for your reply.
I tried seeing the controller in MAX using both straight and twisted ethernet cables, but it can't see the controller in safemode. It seems the ethernet port isn't functioning at all, as I can't set the IP using the RT Apply Target Network Settings VI (through the MAC address). I was hoping I could reimage the controller using the RT Apply Target Disk Image VI or with MAX, but seeing as the IP can't be set then that's out of the question.
I did try changing the boot parameters of the unit through the console output in the hopes I could get it to boot from a USB stick rather than the internal memory. After pressing a key to stop the auto-boot, I used the c command to change the boot file from /c/ni-rt/system/vxWorks to /u/ni-rt/system/vxWorks, but upon reboot it still came up with the same 0x9 error. It was just a bit of guess work on my part, and I know these commands are more the domain of NI engineers rather than consumers like me, so documentation is understandably scarce.
We'll be sending the controller off for repair/replacement today, so it seems it shall remain a mystery as to the root cause of the problem.
