LabVIEW Embedded
CooCox CoOS use in Cortex-M0
CooCox have release their examples for Cortex-M0 seiries.
I find they have made some CoOS example MDK,IAR and CooCox CoIDE.If you use MDK or IAR or CoIDE,you can get the CoOS example on their website for CoOS.They often release CoOS for free on the internet.
Using CoIDE you can use their CoOS very quickly and easily, for they have add CoOS components in CoIDE.You only need to edit your task codes or modify a few codes because the source file of CoOS is writen by CooCox team.The OS example in CoIDE can teach you how to create your task and how to make the OS work.The webpages on the Internet will help you to use the CoIDE.
I'm very interesting on it.
The website of CooCox is: http://www.coocox.org/
The forum of CooCox is: http://www.coocox.org/Forum/forum.php?id=1
Message 1 of 1
(6,817 Views)
