LabVIEW Embedded
Could not stop ARM device!
Hello!
First excuse me for my poor english... I begin to work with Labview embedded for ARM with the MCB2300 (Labview2010). At the beginning, I worked on I/O and I had no problems. After, I would test TCP/IP connection and web server ; because it was not a succes I worked woth exemples of uvision4.
Now, I could not work ; I have this message with Labview:
[14:23:23] Status: Error
EVALUATION MODE
Running with Code Size Limit: 32K
Please check the JTAG cable.
Error: Target DLL has been cancelled. Debugger aborted !
Detail: [UVSC_DBG_ENTER, MSG: 0x2000, STATUS: 0x1] (1)
Status: Run failed.
I have this message if I would work with uvision: "Could not stop arm devices! Please check the JTAG cable."
(8,569 Views)
This link explain that this is a uLink2 error:
http://www.keil.com/support/man/docs/ulink2/ulink2_errors.htm
I think this could be useful for you
Best Regards
PS: vous pouvez poster en français si cela vous arrange.
David S.| Certified LabVIEW Associate Developer
National Instruments France
(8,556 Views)
Merci pour votre réponse! Le problème est résolu.
Ma réponse pourra peut être servir à d'autres ; j'ai enfin réussi à utiliser Flash Magic. Voici quelques précautions.
 . alimenter la board (ne pas brancher le câble série)
 . dans "Flash Magic" -> Tools Terminal
 . appuyer sur RESET de la board et brancher le câble série en COM0 de la board, relâcher le RESET
=> la board renvoie le message 'Synchronized', on peut maintenant dialoguer par le port série
(8,529 Views)
