LabVIEW Embedded
Could u plz help me to find simple example for how to save data file in a spread sheet or any other way in the real time controller for Sbrio 9642 using memory or usb flash memory
(5,750 Views)
Here are a few Links to a helpful Knowledge Base article and a White Paper that should help you out: http://digital.ni.com/public.nsf/allkb/BBCAD1AB08F1B6BB8625741F0082C2AF  and https://www.ni.com/en/support/documentation/supplemental/09/best-practices-for-target-file-io-with-l... . The methods for File IO in Real Time are the same for all of the Real Time Targets. The White Paper has best practices for the File IO and goes over how to do it.
Alex D
Systems Engineer
Academic Research
(5,737 Views)
