LabVIEW Embedded
Deploy web service on ARM processor
Is it possible to deploy a web service to a ARM processor with the LabVIEW ARM module?  If not, has a web server for an ARM processor been done in LabVIEW before?  Is there any example code out there?  Thanks.
(6,712 Views)
Accepted by topic author skryger
skryger,
As of LabVIEW for ARM 2009, there is no prebuilt way to deploy a web service to an ARM processor.  (The only options under Build Specifications are Application, Source Distribution, and Zip File.)  That of course doesn't eliminate the option to build one yourself.  Perhaps someone from the community can elaborate further if this has been done.
Kevin S.
(6,703 Views)
