LabVIEW Embedded
Developer Days 2014: Data Communication For Scalable Systems.pptx
Your prototype system works, but now what do you need to consider before scaling it up to multiple systems?  This session will consider several real-world use cases (1:0 headless embedded controller, N:1 waveform data aggregation, 1:N command stream distribution, N:N status monitoring, etc) and offer recommended communication architectures to address each of them.  We'll also discuss pitfalls of choosing the wrong architecture along with key decision points where you can evaluate your needs and avoid problems down the line. This session focuses on inter-node communication.
Cheers,
Matt Pollock
Message 1 of 1
(5,823 Views)
