LabVIEW Embedded
Embedded and Altera NIOS soft-processor
Has anyone seen the Altera NIOS (or NIOS II) soft-processor being used as a target for LabVIEW Embedded?  I read one little blurb on a pdf stating NI was showing it at a trade show, but have found nothing else on it.
Michael RW
(9,875 Views)
We loaded the standard core onto the NIOS II and modified the Unix Console target to call the command-line tools for the NIOS from LabVIEW Embedded Development Module. It would be interesting to see someone make use of the C2H compiler with the generated code.
Michael P
(9,861 Views)
