LabVIEW Embedded
Error CARD SD undefined
I'm using a MCB2300 board and when i want to compile my project it give me the error: identifier "CARD_SD" is undefined.
Do you know what i can do? I am a beginner.
P.S:When i take the example from the keil software "blinky" or other, it works.
Thank you
(5,969 Views)
Hi kwik76,
I noticed nobody has been able to help with this issue you came across. Have you had any luck in getting this to work? I've had a search through our internal database for the error message you see but found no useful documents. Is this a LabVIEW error message, or part of a 3rd party environment?
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(5,957 Views)
