LabVIEW Embedded
FIFOs with ARM
Hi All,
I need to observe some variables of the VI running on LM3S8962.
So I tried to use shared Variable and connected the board to the PC thru RJ45 but I dont see my variables changing on desktop.
Any one knows what's happening?
thanks
(8,675 Views)
I forgot to join the project
(8,672 Views)
Actually, I cannot debug your project because there are files missing in it. Can you zip the folder of your whole project and then send it ?
(8,639 Views)
here is the project
(8,628 Views)
Actually your project seems good. Did you launch the Embedded Variable Connection Manager ? Can you post a screenshot of it ? Do you see a client in it ?
(8,615 Views)
Here is the screanshoot:
there is an error
(8,595 Views)
here is a screenshool and a simple project where shared variables doesn't work.
(8,523 Views)
