LabVIEW Embedded
How are software triggered timing sources setup for ARM
How are software triggered timing sources setup using LV 2009 Embedded for ARM?  There is an NI example using RT, however the timed loop configuration VIs are slightly different.  http://decibel.ni.com/content/docs/DOC-9859.  I've been able to initiate a software triggered timed loop, but I can only have it execute 1x.  I'd like to be able to fire the timed loop any time that I use the Fire External Timing Source.vi.  The hardware I am using is the LM3s8962.
(6,685 Views)
Hi Frosturi,
I have tried your code in on a simulated device and it seemed to work as you wish. I am in the process of getting some real hardware to test it on. What ARM board are you using?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
(6,664 Views)
HI Will,
No need.  I took a closer look at the RT example and noticed that the triggered timed loop does not have the stop conditional terminal wired.  I made that change to my VI, and now it works!
(6,651 Views)
