LabVIEW Embedded
How do you mask bit in uint32 words that are being read from a DMA FIFO?
Have an host.vi application that is reading /writing binary Uint32 data streams to and from a DMA FIFO. I need to mask (AND) each Uint32 in the stream with 0x3fff3fff. I do not know how much data will be sent in each stream. When I try to use a constant and AND.vi the constant becomes an array constant. I dont want an constant array and I will not know how long the constant array would have to be.  I just  want to AND each value from the FIFO with a single fixed constant (0x3fff3fff).
Any help would be greatly appreciated,
Dave
(4,993 Views)
Hi Dave,
Your on the right track.  The standard AND function will do this. When you have an array as one input the second input automatically becomes an array as well but you should find you can still wire just a constant to this and the function will adapt to it.
Because this is a native function in LabVIEW it should also be the most efficient way of doing this.
Hope this helps!
James McN
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
(2,792 Views)
