LabVIEW Embedded
How to read multiple values using serial communication
Greetings!
I am trying to display multiple values (time constant, capacitance,..) from Arduino Uno on LV front panel.
After trying out some other possibilities how to display my values the closest to my goal is where I used match pattern function. The problem I get here is that results are displayed alternately (but each on it's own indicator).
So the question is what should I do to show my values on indicators at the same time? Or should I look up to some other LV function to achieve this?
Thank you in advance.
Message 1 of 1
(4,045 Views)
