LabVIEW Embedded
I would like you to suggest me a board for 400 senors used for road monitoring
I would like you to suggest me a board for the following componets:
1) Load Sensor
2) Geryo Sensor
3) Moisture Sensor
4) Temperature Sensor
I am currently working on " Road Deformation System" project. I am using load sensor to measure load in range 12-28 tons/axle, geryo sensor for deformation, moisture sensor to measure water level and temperature sensor for temperature changes. The input maximum ranges to 400 sensors.
I would also like to store all the measured data in hard disk and transmit the data through GSM.
So it is kindly requested to suggest the board for the project.
(6,183 Views)
Hi Qamar123,
It sounds like you'd need a combination of cards. I'd probably recommend using a PXI system with several cards in it that could perform the various tasks you need. You can check out the PXI Advisor Tool on the National Instruments website, or you could call a sales representative, who would be more equipped to help you spec out a system like this.
David S.
(6,155 Views)
