LabVIEW Embedded
Installing Blackfin Test Integration Toolkit
Hello
where can i find the necessary files (Blackfin Tookit.exe) to install this Toolkit for LabView Embedded Module for ADI Blackfin Processors board?
Are there further (free) Toolkits available for this board?
Johannes
(8,115 Views)
The Blackfin test integration toolkit allows you to use LabVIEW on Windows to connect to a board with an ADI Blackfin on it so that you can control the Blackfin on the board. Using this toolkit, you will be able to automate the Analog Devices (ADI) VisualDSP++ development environment and communicate bi-directionally to your Blackfin processor using Background Telemetry Channels (BTCs). It's typically used by test or design engineers who want to test their hardware or the C code running on their Blackfin.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=EEBFA0D90A3C1C75E0340003BA7CCD71
Joel Sumner
NI-Shanghai
(8,109 Views)
Thank you very much for your help and your fast response!!!!!
Smiley Very Happy
(8,104 Views)
