LabVIEW Embedded
Is it possible to program LM3S8962 without ULINK2 JTAG?
Thanks for helping, really thank you very much
Message 11 of 21
(4,358 Views)
please if you could put a imagen.Ya can not find the EK-LM3S8962 USB, THANK
Message 12 of 21
(4,358 Views)
Here is the dialog showing the required selection:
Message 13 of 21
(4,353 Views)
ME NO OPTION APPEARS ek-LM3S8962 USB, EK-LM3S8962 FIGURE ONLY. NEED TO MAKE ANY MODIFICATION IN THE ARCHIVE
Message 14 of 21
(4,349 Views)
The "LM3S8962 USB" is only in LabVIEW embedded 2011, if you are using another version is necessary to do the procedure I mentioned in the first answer.
Generate your code using the option "LM3S8962", compile it in the Project Explorer and right click on the icon of the ARM, then select "Show Keil uvision". In uvision window, click Flash -> Flash Tools Configure and select the form of programming (Luminary), then click on Flash -> Download. After that initial configuration, you can download the code direct using LabVIEW, but sometimes it fail... This is normal and I recommend you to use uVision to download.
I hope this helps!
Evandro
Message 15 of 21
(4,339 Views)
I figure this error, how I can fix it? I have a EKS-LM3S8962
error.JPG[03:23:06] Status: Error
Timed out waiting for a response
Detail: [UVSC_DBG_ENTER, MSG: 0x2000, STATUS: 0x1D] (29)
Status: Run failed.
Message 16 of 21
(4,316 Views)
This error likes to be a installation problem in uVision or in the EK-LM3S8962 driver.
First of all, what version of LabVIEW and uVision do you have installed? Do you try to uninstall and install all again?
Two, when you connect the board in the USB, go to "System Properties" in Control Panel and click in "Device Manager". There are some hardware with a "?", if yes, what is the name? If you don't have installed the board driver, it is here: http://www.ti.com/tool/lm_ftdi_driver .
If you give more information, we can help you in a better way.
Message 17 of 21
(4,311 Views)
I have labview 2011 and uvision4. In the Device Manager include 3 isgnos of (?) In the stellaris. thanks
Message 18 of 21
(4,309 Views)
and fix as you indicate your, thank evandro. now how do I run my lpc2468 development board without the connector j-tag. thank you very much with all my heart. I have labview 2011 and uVision 4. also need to install the drivers as I indicastes with ek-LM3S8962?Dibujo.JPG
Message 19 of 21
(4,301 Views)
About this board, I think I can't help too much because I only have experience with LM3S8962...
But this is exactly the same photo of a board in this page: http://www.ni.com/white-paper/7066/en . This is a Tier1 board and apparently have total support in LabVIEW like LM3S8962. The driver will be other, try a search on the forum and in Google about it and LabVIEW to verify if the ulink cable is really necessary.
Message 20 of 21
(4,297 Views)
