LabVIEW Embedded
Is there some update of CoBuilder?
What's the current version of CoBuilder?
Whether it is updated  from time to time?
Is there any enhancements in the latest version? What are they?
Best regards!
Thanks!
(7,215 Views)
Yes, not only CoBuilder was updated very often,but also CoDebugger and CoFlash included were updated for each
a long time.
CooCox CoFlash has been updated to V0.3.(Early version is 0.1 and 0.2)
CooCox CoDebugger has been updated to V0.12.(Early version is 0.1 and 0.11)
CooCox CoBuilder has been updated to V0.15.(Early version is 0.1 and 0.14)
The detail information of their Corresponding enhancements, you can get from the their official website:
<a href="www.coocox.org">www.coocox.org</a
(7,201 Views)
a long time.
www.coocox.org
(7,200 Views)
Using CoBuilder needs JAVA platform  and GCC compiler. GCC compiler I understand,but
the former—JAVA platform,including JDK and JRE.  If are they(JDK and JRE)  all need to be installed?
Best regards!
Thanks!
(7,178 Views)
JAVA platform,including JDK and JRE. They are not all need to be installed. You just need to install JRE.
JRE——JAVA Runtime Environment.
Because,CoBuilder, even CoDebugger,the studios of them are all developed by Eclipse,the famous development platform. So their running need a JAVA Runtime Environment. That's JRE. You just need to install and configure JRE software. It's enough and you needn't to install others.
www.coocox.org.
(7,164 Views)
Based on the profiles you posted during the past six months,  I think you should be a
Program developer in CooCox organization. Yes?
I'm very interested in CooCox software, so I want to ask you a question. Is there a
professional specifically forum for coocox?
I want to exchange technology problems about coocox products with some professionals
who are also interested in coocox.
Looking forward to your reply! Thanks!
(7,125 Views)
Yes. There is a professional specifically forum for coocox.
We are dealing with the last work about this forum. It will be published and promoted in recent days.
Thank you for your supporting!
Thanks!
www.coocox.org
(7,116 Views)
