LabVIEW Embedded
Issue with hybrid mode
I am using NI 9076 controller in which i have configured the module in hybrid mode(i am using three modules, two modules in scan mode and another one module in FPGA interface).
if i use the default module configuration, i am able to run in hybrid mode without any problem, but if i do some changes in the module configuration(changing single ended to differential ended and digital input/output), i am unable to read any data from the channels under scan mode.
Kindly help me out to resolve this problem.
Message 1 of 1
(5,941 Views)
