LabVIEW Embedded
LM3S8962 change IP
I have the Stellaris Evaluation Kit "EKK-LM3S896". I´m using LabVIEW 2009, embedded modul and kile for the programming. Now I would like to know how I can change the IP of the board programmatically. I can´t find something about. Are there some VIs to do this?
Thanks for every answer.
jreinhart
(6,924 Views)
Hello Johannes,
is this board related to Texas Instruments? I don't know anything about a Stellaris Eval board.
If so, please contact TI.
Tobias
(6,908 Views)
Oh,sorry, i just found this:
How Do I Configure a Luminary Micro Stellaris ARM Target?
Message Edited by TobiD on 03-26-2010 02:37 PM
(6,906 Views)
Tobias, here it is another link (the Stellaris board is on the left) http://sine.ni.com/nips/cds/view/p/lang/en/nid/205040
Getting back on topic, here it is a useful link http://www.keil.com/support/man/docs/rlarm/rlarm_tn_config_title.htm
However, modifying the IP at runtime is mutually exclusive with TCP debugging.
(6,900 Views)
thank you for the answers. I have looked the links, but I can´t solve my problem. Could it be that I cannot do what I want with the Labview C node? But if someone did something similar let me know 🙂
Thanks to everybody.
(6,880 Views)
