LabVIEW Embedded
LV Embedded + ARM7
is it possible to use LV Embedded module on ARM7 processor??? Is the requirement of 256Kb RAM critical???
Marcin
(7,835 Views)
Hello Marcin,
Yes, we have seen LabVIEW running on an ARM7 running eCos as an operating system.  There's no reason that it shouldn't be able to run in other configurations as well.   As is the case with any LabVIEW Embedded Development Module target, however, this will require some up front integration work by you in order add support for the target to LabVIEW.
It's not critical that there be 256K of RAM for the applications to execute, however, you will need at least 256K of program space  (this can be RAM or FLASH ) in addition ot  whatever is necessary for your OS or support libraries to have enough room to develop a reasonable LabVIEW Embedded application.
I hope that this helps.
P.J.
(7,829 Views)
