LabVIEW Embedded
LabVIEW ARM break after update Front Panel during debug
I try to debug the vi by Ulink, the vi just show the LED blinking for 500ms on/off with while infinity loop, after click run button the loop continue working about 5 second and then break button actived with front panel update. Is this normal working?
Thank you
Message 1 of 11
(9,139 Views)
Can you be more specific about "then break button actived with front panel update?"
Charlie M. CLD
Message 2 of 11
(9,114 Views)
After I click Run button on the toolbar the vi start ranning, the LED blinking show on the hardware but not update to the vi front panel, around 3 second the vi stop (like a we click on Pause button on toolbar) and update the status LED to front panel.
I used ULINK1 for this example, I don't know this cause of the problem or not.
Thank you.
Message 3 of 11
(9,108 Views)
Does this occur with any other VIs, or just this specific one?  Is the time period consistent, or does it vary?  Can you confirm that you still have a good connection to the board after the VI stops?
Jeremy_B
Message 4 of 11
(9,079 Views)
Yes, it occur on main vi any project. The time is consistent if I click on pause button again the vi will continue and after that 3 sec the vi will stop again. I confirmed I have good connection because I can download to the board, the debug working except the vi stop all the times(after stop I can click pause to continue).
I tried to open the Keil uVision3 project from the folder that generate from LabVIEW and run to debug mode(no LabVIEW running), I did not got any problem, the ulink run's led status showing. If I call Keil uVision3 from LabVIEW project and run in the same way, the debug mode will stop after 3 sec, the ulink run's led status show 3 sec also. This problem look like LabVIEW stop the debug process.
Thank You.
Message 5 of 11
(9,071 Views)
Which ARM board are you using, and which version of LabVIEW?
Jeremy_B
Message 6 of 11
(9,059 Views)
Thank you for your response, MCB2300 board with ulink1, 60 day LabVIEW ARM v8.5.1. How many version of LabVIEW ARM?
Message 7 of 11
(9,047 Views)
Do you have another computer you can try it on?  It could be a bad installation of LabVIEW, in which case you could try doing a repair installation.  You can do that from the Add/Remove Programs >> National Instruments Software in Control Panel.
Jeremy_B
Message 8 of 11
(9,024 Views)
Thanks, I will try to install to other computer. Can I have new LabVIEW ARM 1.1 evaluation to try and where I can download?
Message 9 of 11
(9,012 Views)
Here's the link:
http://joule.ni.com/nidu/cds/view/p/id/1049/lang/en
Message Edited by Jeremy_B on 11-10-2008 09:56 AM
Jeremy_B
Message 10 of 11
(8,993 Views)
